exaggerated expressions
I don't know if it is right section to post this. Please admins, move it where it should be.
Some part of expressions I use, is suddenly exaggerated.
Left one rendered in december. Right one opened today, no change to slider's value.
When set at half of prevoius value - it looks normal.
in this case - from 75.34%% to ‭37,67‬%
Any ideas what could be causing this?
It's not the case of figure rigging.
Already checked it.
  • GordigGordig Posts: 10,678
    Do you own Auto Face Enhancer?
  • rebelgraphxrebelgraphx Posts: 224
    In parameters go to actor > pose controls > head > expressions  and check if there is a section called AFE real expressions. If so there should be a slider that is set to 100% called master controler. That's the one who causes the problem with my expressions
