[Out Now!] Trophy for Genesis 8! - props and shader presets[Commercial]
Silent WinterSilent Winter Posts: 3,884
edited April 2020 in Daz PA Commercial Products
Edit: Out Now: Trophy for Genesis 8!
https://www.daz3d.com/trophy-for-genesis-8
Give your characters the recognition they deserve!
This is a set of props and shader presets to turn Genesis 8 Male and Female into trophies.
It comes with materials presets for G8F and G8M and shader presets to integrate other content. Presets for Gold, Silver, and Bronze trophies.
The props load as wearable presets, posing the hands/arms as necessary (so load them after posing your character for best results).
More promos on the store page
Click thumbnails below for more pics / larger size
Post edited by Silent Winter on
  • Looks awesome! I love your creativity.
  • SigurdSigurd Posts: 1,094
    Trophyception is so cool.
  • Silent WinterSilent Winter Posts: 3,884
    Thanks Missuskisses :)
    heh, thanks. It was something that I just realised I could do while testing out the product, and having put trophies in the trophy's hands once, I had to follow that line until the render wouldn't show it anymore :)
  • GoggerGogger Posts: 2,496
    edited April 2020
    Looks AWESOME!  Hopefully the bases will stretch enough for things like horses and Centaurs and the like!
    Post edited by Gogger on
    They should scale well enough (since they mostly use shaders too) - if you stretch in x and z but not y, they'll probably get stretched a bit on the '1st Place' text but everything else would be ok - you can always make new text (black on white) as a bump map, or use no maps and add the text in postwork. Alternatively, add a primitive cube/cylinder to the top, scaled to the shape you want, and add the included shader preset to it (possibly needing to turn off 'smoothing' in the surfaces tab).
  • XenomorphineXenomorphine Posts: 2,421
    Could always simply shrink the centaurs and stuff down, instead.
    True - but they might appear relatively too small on the top of the 'pillar' trophies (would work well on the shorter base)
    If so, just add an additional oblong/oval/triangle of the relevant dimensions and apply the relevant shader, then parent the main trophy prop to it.
    Yep yes - the included shader presets make customising pretty easy smiley
  • Hmmm, your store is listed with todays promo but your trophy product is not available. Strange?!
    The Trophy product is 'Coming Soon' - it's through QA and awating a release date - my store is on sale for my new release: The Old Shopping Arcade - but since I'm quite a new vendor, I think there's only the Chess for Genesis 8 that isn't 'New' at the moment. (My 2nd product 'Tornado Bar: Fight Bar' was released Feb 21st and my 3rd was a DO buyout released mid-March).
    Hopefully the Trophy set won't be too long :)
    Trophy for Genesis 8 is out now!
  • I'm trying to light this trophy and no matter how much I boost my spotlight's luminance, the trophy stays almost black in NVDIA. Any suggestions?
