dforce clothes explaoding
KeithH
in The Commons
Sometimes DForce works and other times it does this. I have no idea hot to fix it.
This outfit worked fine in previous scene. I even deleted and put the outfit back in to see if that makes a difference. Nope not at all.
Thanks
https://www.deviantart.com/chachah/art/dForce-experiments-745775306
This helped me with the majority of my exploding content. If its an object that you've had success with but sometimes it explodes, this should help. Some objects are just bad for dforce, though.
That is strange for a this to happen to a dforce item, usually you see that on older non dforce clothing that has been converted.. But the best way to fix this issue is to put the bend stiffness setting to around .25, that should stop the item going kaboom..
The right arm of your character is intersecting, passing "through," the frame of the object in your scene, in a place where dForce has to operate.
DForce cannot compute how to "drape" through another object. The relevant limbs or other anatomy of the character being clothed cannot intersect other objects, including other limbs or anatomy of the character itsel. In animation, that applies even to transitional, momentary intersections. Pretty much a guaranteed explosion.
