Sci Fi Training Room texture replacement glitch
I have Sci Fi Training Room. I like to use iRay shaders. I set a couple of surfaces as Daz Uber Base. These parts stayed alright initially, however, as soon as I turned on Emissive part of the shader, this happened (image).
What is this, and how do I fix it?
Things I've tried:
  • Resizing the texture
  • Adding a different shader (MEC4D's PBS Shaders)
  • Rendering with spot render, rather than iRay preview mode
  • TSasha SmithTSasha Smith Posts: 27,368
    If you are talking about this https://www.daz3d.com/sci-fi-training-room I got it.  I am not at my computer at the moment as I am eating breakfast.
    what textures are most problematic?
  • CyrinadiaCyrinadia Posts: 164
    None, the textures are as provided, it's the Daz Uber Base Shader that seems to be the problem.
    Ok, I tried using a different included 'Set': Scifi_TrainingRoom_BasicDSLights. Seems the base iRay shaders and the Uber Environment lights (the other two sets) don't like each other, though the base light set works well.
  • scorpioscorpio Posts: 8,533
    Looks as if you may have 2 of something loaded.
  • Richard HaseltineRichard Haseltine Posts: 108,958
    The product page doesn't list materials presets, it lists pre-load scenes. You need to delete the one version before loading another, as Scorpio says this is what happens when there two versions of a model in the same place.
