DS 4.12 Completely white - Solved
AJ2112AJ2112 Posts: 1,417
edited April 2020 in The Commons
Hi, been away from DS for a few months, tonight I upgraded to DS 4.12, I start DS up and all I get is a complete white program screen.  I tried uninstall/reinstall, rebooting system, etc...... I should have just stayed away.  Goodness gracious, Rofl !!!!
Has anyone else had this type issue.  Assistance appreciated.
Post edited by AJ2112 on
  • AJ2112AJ2112 Posts: 1,417
    Got it working.  In case others have this issue, directories had changed.  How, no idea.  I noticed in DIM, downloads/installs were failing.  I was able to open Content Directory Manager, clicking around on white screen, Lol
    ! changed directory paths......  back in business.
    DS is gonna make us all computer software experts in no time wink
  • Richard HaseltineRichard Haseltine Posts: 108,907
    That issue is usually down to installing while DS was still running (possibly only in the bckground, as it shut down).
    Hi Richard, you are correct, believed I had DS open when I upgraded, which caused all types of problems.  All is working well.  Thanks so much friend.
  • Having the same problem all white screen went to content database maintenance a drop down menu popped up with several options. Clear all groups, Condence Database, Process Metadata Queue, Re-import Metadata, Export user data and reset database. Which one should I pick? Thanks
    edited November 2020
    None - and all white screen has nothing to do with the database. You need to make sure that DS really is closed, then uninstall and reinstall.
  • edited November 2020
    Thanks Richard I'm back on track.
  • Glad to hear (read) it.
