Iray render problems. Image is being cut.
BigMacBigMac Posts: 97
In the render settings window all figures are there, but in Aux Viewport a figure is cut (see picture). I tried a lot to find out what it was, but to no avail. Please help.
I thank you in advance
Reza
  • scorpioscorpio Posts: 8,533
    Try using a Camera rather than the perspective view.
  • Richard HaseltineRichard Haseltine Posts: 109,342
    Are you sure you don't have an Iray Section Plane loaded?
  • BigMacBigMac Posts: 97
    Hi,
    where can i find iray section play. Is it possible in render settings?
    Thank you
    Hi,
    it didn't end.
    Thank you
    Hi,
    Thank you
    It is added through the Create menu, and will appear in the Scene pane like any other object - I was asking if you had one, not suggesting you add one if not.
    Sorry I misunderstood you.
    No, I examined everything. I have not found a section plane in the scene.
    Thank you
