Help, strange morphing
Hi,
Hoping everybody is fine,
I’ve got a problem with morphing one leg, not always but with some specified poses (No problem with standing poses) The result is just ugly. Any help is welcomed.
Best regards
  • Richard HaseltineRichard Haseltine Posts: 109,540
    Does it go away if you zero the shape? Is there just one shape applied to the figure, or is it a mixture?
  • Hi, thanks for your answer/question, it doesn't go away if I zero the shape, the shapes have been generated for all the body not only this leg and same problem with a mixture or even an unique and clean pose
    In order to fgure out the guilty part you need to find the minimum pose/shape combination to trigger it - that will make the list of properties to check through as short as possible.
  • Ok, thanks, I'll do that and let you know if it's working
