Cannot find a purchased character
I apologize before hand for my complete noob status. I'm enamored of this software and purchased a few items and was having great fun playing around.
However... I purchased a character called "Raphael" in the store. He required the Michael 4 model and the morph++ of that. Got both.
My issue is that I cannot figure how to load that particular preset.
Again, I'm sorry for being so new to the whole thing. Just don't know where else to ask.
Thanks!
I don't have this character and the online readme is just a place holder.
Did you install this with DIM? If so select this item and right clck on it. This brings up a menu. Select show installed files. There probably will be an HTML readme file listed. Click on that file. This will open the file manger on this file. Open it in a browser. This is an old readme, but they usually tell you were to find the item.
If you did not use DIM, then look in the zip file you downloaded. You should be able to find the readme HTML in it.
It will probably be under Poser Formats -> -> Poses somewhere. You can also look at the installed files for .pz2 files under the Runtime-> Poses directory.
You will need to load Michael 4 in the scene with his Morph++ injected. There should be Head and body injections pz2 for this character you can apply to change the body shape. There should be skin mats to apply the skin and other options.
These are the most common places for character like this. If you can find the readme it will make it easier to find.
For this you will need the Content Library Tab, Most of the content needed to fully create the figure with the Morph set is going to be found in the Poser Formats section of your default content folder. M4 will be in the Poser Figure folder and the rest will be in other folders. Like the Mats (skin textures) will probably be in the POSE folder as textures in Poser are a pose file. This takes getting used to.
As noted above reading the README is often a big help in finding the older content. I hope you find it all easy to do. I love DS.
