Crossdresser for Toon Generations available now
wsterdan
For any Toon Generations users, Crossdresser license for Toon Generations is available at the EvilInnocence Store now.
I'm planning on playing/working with it later today and will post some results.
-- Walt Sterdan
Post edited by Chohole on
This should make the Toon Generations user VERY happy! Looking forward to seeing some conversions.
-MJ
Here's the first try, M3's Project Z on Toon Generation. So far, so good.
-- Walt Sterdan
... and it's on sale at the moment
The website states :"Purchasing this license allows you to convert clothing from any supported figure to Toon Generations." Okay, well what does that mean? Are we talking the ability to convert generation 4 clothing, genesis or what? And what does "any supported figure" mean? All of the toon generation characters?
Any supported figure means any figure that has Crossdresser support. You buy a license for the "to" figure. The from figures are built in if they are supported.
A couple of simple conversions, absolutely minimal tweaking done. I'm sure taking the time to do it correctly would yield better results, but at the moment I'm just playing with a few different pieces.
Very nice renders. I have bought the licence for myself yesterday. How did you do with the shoes and boots?
Are you hiding feet on the figure? I have just tried conversion from one of M4 clothes set and the most pokethrough is coming on the boots.
What kind of lighting are you using? Is it in Poser? Sorry for so many questions...
Hi;
Please don't apologize for asking questions, they're never a problem.
The boots above converted fairly well. I add a few morphs using the program Morphing Clothes by Dimension3D (available at Renderosity). It allows you to copy morphs from the character or the original clothing. All of the clothes converted had the Toon Generations morphs injected, so the clothes could work for male and female, heavy or skinny, buff, etc.
I didn't have to hide the feet, but I tend to hide everything that doesn't show by habit, that way when I change a pose, I don't have to worry about something new poking through that didn't show through in the previous pose.
The lighting was Omnifreaker UberEnvironment in DAZ Studio; I also applied the pwToon shader to almost everything.
Hope that helps.
-- Walt Sterdan
Glad that Toon Generations is supported. Once I can I will try to get the license.
Thanks a lot for the answers, Walt. I have bought Morphing Clothes a long time ago, but have not used it recently.
Time to refresh my memory about how to use it efficiently.
Are there any Morphing clothes tutorials out there?
I just got the Toon Generations licence.
I must be doing something wrong because even if the FBMs show on the converted clothing I can't get them to apply.
Thanks for your help.
Hi;
Sorry things don't seem to be working for you; were the FBMs from Toon Generations, or from the clothing itself?
I haven't played much with the FBMs from the various clothing, I normally go quick 'n' dirty with a straight conversion (using only a single, full-body Conversion Adjustment of "1.00"). Once the conversion is done, I use Morph Clothing to move the Toon Generations into the clothing.
-- Walt Sterdan
Thank you Walt for trying to help me. Great image by the way.
I am new to crossdresser (I was used to wardrobe wizard!).
I make the conversion and fit the clothing to Toon Generations with no problem but when I want to morph Toon Generations the clothing does not follow (or if I manually dial them) even if the morphs are listed. I do not use (or own) Morph Clothing.
You can see what I mean on the following image.
Thank you.
Looks like the issue you have is the clothing does not have the morphs you need in them. This is what Morphing Clothes does for you. I am not aware of any other solution to accomplish this.
-MJ
Thanks everyone!
I found a way to make it work by using "Transfer Active Morphs" in DS4 and for extreme morphs adding a smooth modifier.
If anybody knows an easy way to make it work in Carrara, I'd love to know.
Congrats! I would never have thought of it, well done!
-- Walt Sterdan
I could never get Xdresser to work (DS 4.5) Supposedly there will be a new Xdresser option in the dropdown menu as soon as you load DS up, but I never saw it anywhere.
I use crossdresser as a standalone. Universal clothing plugin is suppose to do what you're talking about but I didn't try it.
Is there a Warbrobe Wizard Kit out yet?
