Problem with fitting "Michael 4 for Genesis 2 Male" to "DS Dynamic Jeans for M4" or "M4 Dynamic Pol
Hi,
I've been able to use the Slosh plugin "Michael 4 for Genesis 2 Male" with other clothing items, applying them to Genesis 2 but "DS Dynamic Jeans for M4" doesn't seem to work at all.
There is no "Auto fit" or "Fit-to" option no matter which way I bring it in (with character selected or dragging and dropping or without character selected).
The jeans come in 'un-selectable' but even after I change this in the Scene tab nothing improves
Even with a geometry smoothing modifier it doesn't seem to work.
I'm having similar problems with "M4 Dynamic Polo Shirt".
Is there a solution? (other than buying Michael 4 Base...)
Post edited by yardley.joe on
DAZ Studio dynamic clothing cannot be autofitted to G2M. With that having been said, just parent the items and potentially do some pose adjustment and do a drape. Depending on pose do a dynamic drape using the animation timeline. They should fit G2M reasonably well unless you exaggerate morphs lot.
Edit: Just in case you don't know, these dynamic items (from Optitex) require the dynamic control tab and there you can initiate the drape and, depending on whether you got the full control or the basic control (latter included in DAZ Studio), adjust some parameters. The rigging these dynamic items got is only basic anyway, to aid with some poses. So they should still work fine.
http://jv-andrew.deviantart.com/journal/Using-V4-DAZ-Dynamic-wardrobe-on-G2F-431424983 this may help, same process for G2M.
Its pretty simple really, just position the clothing in a TEE pose and then Scale it up enough it can collide with all areas needed when the sim is run. Dynamic items will shrink back down to the proper size or until it collides with the properly flagged mesh. That is how I put items on figures they were never made to fit. Like the Brunna Morph for V4.
