PLEASE, PLEASE Help...cannot remove Look at my Hair window from Daz3d.
gizmo1029gizmo1029 Posts: 0
I opened up a panel for look at my hair. It is now on the top of my screen and everything else is at the bottom and barely visible. I cannot move the panel for look at my hair and I can't get it off my screen. I have uninstalled Daz 4.6, reinstalled it. I Uuninstalled it again, reinstalled Daz 4.5, and restarted my computer. Can someone please tell me how to get the panel off my screen so the panels at the bottom can be visible?
  • SzarkSzark Posts: 10,634
    I don't know how exactly as I have never seen this beofre but you might try going to the top menu bar in Daz Studio > Windows > Workspace > Layout and reset the layout, accept and see if that fixes the issue.
  • JaderailJaderail Posts: 0
    edited February 2014
    If it did not Load with a Default OS x close button your system failed to create the interface properly. I would do a FULL Hard shut down. Ctrl Alt Delet Task manager and reboot to see if it Builds the next time. If not the Program is not working correctly...
    437 x 707 - 26K
    Post edited by Jaderail on
    If that is an HP laptop and happens to have an Intel graphics chip...it may not be of any use. If that's the case, then it's a OpenGL problem with the Intel drivers.
    And the only fix is going to be a video driver update...if there is one.
    Post edited by mjc1016 on
  • fixmypcmikefixmypcmike Posts: 19,701
    It's not a software problem, the top of the pane is just obscured. Switch layouts and it should be fine.
    That was hard to tell from the photo. I wish more would use the Snip Tool to post images here. That would help.
    I have never used the snip tool...humm off to look it up.
    Comes with Win7 in Accessories.
  • Richard HaseltineRichard Haseltine Posts: 108,488
    Snipping Tool is the full name.
    opps sorry yes found it and learnt how to use it, very cool. thanks
  • MadbatMadbat Posts: 388
    I still have an entry for LAMH in windows/tabs and windows/panes and in create after I uninstalled the product. Resetting the layout does nothing.
  • fictionalbookshelffictionalbookshelf Posts: 837
    I just saw this but was wondering, have you tried deleting the actual LAHM .dll file? That might help.
