Daz3D 4.6 import error
Hi.. I'm newbie with this software...so please do accept my incompetence as normal...
Right, I have Daz3D 4.6, and as you know there's several websites that offer free stuff (Renderosity, etc) but then comes my headache...
I just can't import anything to Daz3D, it always gives me an error saying there's an error and I should look to my log...
I tried already the Daz3D fix that I found here....with no success...
Now here comes the question... how do I import stuff? (hair, clothes, etc) or where to?
It's pulling my nerves lol
Thank you in advance...
If the content that you are trying to use, is in a format that DS can read (CR2, PP2, PZ2 etc) then you should not 'Import' it, but load it the same way as you load DAZ 3D items, from the Content Library pane.
That means, if it is Poser or DS content, install it into your main DS Library folder (My DAZ 3D Library?).
What format is giving you trouble, OBJ?
.duf
cheers for your quick reply mate
I don't get it seriously... shouldn't .duf be a Daz3D file?
I put everything in "My DAZ 3D Library" some in "people" and others in "runtime" in Genesis...like it was on the file I downloaded which it was mainly "hair"...
DUF is indeed a DAZ File format.
If you have it installed into your DAZ Studio content library, then it should load with a double click like any other file. The problem may be the content. DUF files carry information on where the content that it uses is stored.
For example, if I created a Scene or Clothing item on my PC, saved it as a DUF file, and then sent it to you, it would be no use unless you had EXACTLY the same setup as me, including folder names etc, and the same content.
What exactly is in your DUF files, and what errors do you get when trying to load them. You can look at the log file in Help > troubleshooting > View Log File
ok..give me a minute..
LOG:
Error writing author data!
Total class factories: 1257
WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
3D mouse support library could not be loaded.
Creating interface
Successfully created OpenGL viewport for Viewport1.
Successfully created OpenGL viewport for Viewport2.
Successfully created OpenGL viewport for Viewport3.
Successfully created OpenGL viewport for Viewport4.
Executing startup script...
Started in: C:/Program Files/DAZ 3D/DAZStudio4
DAZ Studio Started
Creating Pixel Buffer
Pixel buffer - Width: 1024 Height: 1024
Compiling OpenGL Shader...
Fragment Shader:
Fragment Shader compiled successfully.
Linking Shader:
Fragment info
0(29) : warning C7050: "_rgb" might be used before being initialized
Shader Program successfully linked.
Loading Startup Scene : C:\Users\user\Desktop\ONYX\- RAR\Material\My Library\People\Dawn\Hair\FreeFashion\Texturen_forGlamHair\dunkelblond.duf
*** Scene Cleared ***
Error reading file, see log for more details.
File loaded in 0 min 1.4 sec.
Loaded file: Genesis.duf
File loaded in 0 min 0.0 sec.
Loaded file: fantasiegruen.duf
File loaded in 0 min 2.0 sec.
Loaded file: Genesis 2 Base Female.duf
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeLimbsSS.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeLimbsM.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeLimbsB.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeLimbsTL.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeLimbsS.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeHeadSS.jpg
WARNING: fileinput\dzassetdaz.cpp(6360): Could not find UV set definition: /data/HiveWire 3D/Glam Ponytail/Base/UV Sets/HiveWire 3D/Base/default.dsf#default
Could not resolve : "/data/HiveWire 3D/Glam Ponytail/Base/UV Sets/HiveWire 3D/Base/default.dsf"
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeHeadTL.jpg
File loaded in 0 min 11.7 sec.
Loaded file: dunkelblond.duf
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeEyesM.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeHeadM.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeHeadB.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeHeadS.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeInMouthM.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeEyesB.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeInMouthB.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeTorsoSS.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeTorsoM.jpg
File loaded in 0 min 21.7 sec.
Loaded file: dunkelblond_fix.duf
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeTorsoB.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeLashes1.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeTorsoTL.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeTorsoS.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/Textures/FreeFashion/Texturen forDawnGlamhair/GlamHairTex2gudsi.jpg
WARNING: Attempting to unlock undo stack when already unlocked...
WARNING: Attempting to lock undo stack when already locked...
File loaded in 0 min 1.2 sec.
Loaded file: FIGURE - Barefoot Dancer.duf
Loaded Morph Deltas in 0 min 0.0 sec.
Loaded file: PBMNavel.dsf
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeEyes6M.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeHead3M.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeHead2B.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeLashes2.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeHead3S.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/Textures/PropsChick/AldoraHair/PCAldoraHairTex01.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/Textures/PropsChick/AldoraHair/PCAldoraHairCapTrans.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/Textures/PropsChick/AldoraHair/PCAldoraHairCapTex01.jpg
DEBUG: End DAZ Studio to Hexagon Bridge log...
--------------- DAZ Studio 4.6.2.118 exited ------------------
and print screen
You are clicking on a texture preset without having the item it is for loaded/selected.
everything is in the right place and in the right folders....
this is so annoying...
might reinstall everything... and start from scratch...
Ok.. probably the best question I can make is when I donwload something from Renderosity for example should I stick it straight away on the My DAZ 3D Library folder and that's it?! will it work this way?
What is causing the error is that it is a material preset for a specific hair. It won't load the hair model, just change its color. You need to load the hair first and make sure you have it selected in both the scene and surfaces. Then clicking on that preset will load the proper textures for it.
Odd enough I just looked and every single file is a texture it doesn't have a main one.... resuming I am really incompetent...
Going to try now if I can load some clothes...
Thanks for your help guys
Do you have the 'Dawn' figure by HiveWire 3D installed, If not, then lies your problem. The hair prop in question comes with the free 'Dawn' figure. you will need to head over to their website and get it from there.
Yes mate... its the "Dawn" one.. I donwloaded as it is on "Renderosity".... I'm sure I'm doing something wrong...
Should I put it on the public folder or my personal folder?
This is really REALLY annoying me...
1st you need to head over to hivewire3d.com, head to the shop and get the free Dawn figure and install the files into their respective Daz3D folders,
you will then find the hair prop under the 'Content Library', In the following folder
DAZ Studio Formats - My DAZ 3D Library - People - Dawn - Hair
See Screen Shot Below,
PS. If you are using the hair prop for any other figure than Dawn you will have to manually adjust the fit.
