Objects that cannot be hidden
Probably a stupid question but I'm flummoxed. I want to hide a wall in a particular object and for some reason when I click the EYE symbol nothing happens and I can't make it invisible (see attached). Is there a lock that prevents hiding objects that I'm not aware of? THANKS
  • Richard HaseltineRichard Haseltine Posts: 109,527
    Are you sure that's the right node? What happens if you move it, using sliders or the Viewport gizmo?
  • Maybe there are 2 of the same objects in the scene?
  • thedoctorthedoctor Posts: 201
    UPDATE: I figured it out. There is a LOCK for object visibility that can be activated in the Parameters tab. When it is activated you can't turn off visibility (see attached).
    889 x 448 - 135K
    Well that's good to know about. Rather odd that it was set though.
