hair and elven type ears
manekiNeko
i think this has been discussed somewhere at some point already... have absolutely no idea where tho.
a long while ago, i read this post/thread about how to deal with hair that cover ears... and continue following with long "elf" ears (or any ears but usually you don't see it). the result is a bunch of triangular hair sticking out of the head instead of the ears peeking out...
there was a simple manip to do on either the figure, or the ears (which wasn't possible by then since it was genesis i think), or the hair or some part of the hair.
or in the morph of the ear... or some morph of the hair.. in the parameter panel, edit (where you have those gears) and uncheck auto-following. NO IDEA WHERE. i tried a few possibilities, to not avail, and honestly, i have absolutely no clue what i'm doing and why.
the only thing i remember was that you were supposed to have something stop auto-following something else.
if it's a part body morph the easy fix is show hidden and dial it down on the hair
full body morphs are more of an issue
meow?? come again? i need detailed info ^^ - i'm not the brightest in tech terms
if your morph is just an ear morph
tick the show hidden box in parameters on the hair and dial it down
aaah now i get it. wouldn't have crossed my mind to look under hidden. thanks a lot :)
EDIT: yay! worked like a charm! thx again!
