IDG Iray Essentials Not Working for Male Anatomical elements
Hello,
I recently purchased IDG Iray Essentials for my characters and the skins work fine. However, for some reason the male gential textures will not load.
I'm using Sledgehammer's OMGDK for G8 males. When using G8 Male genital textures from all different kinds of G8 male characters it works fine, but whenever I try using the IDG Iray Essentials texture it doesn't load up at all.
I have tried reinstalling it with smart content, DAZ Install Manager, and manually installing it but still get the same results. I am using Daz Studio 4.12 Pro with Windows 10.
If anyone has any ideas of what I could try I would greatly appreciate it.
Thank you for your time and help.
Post edited by Chohole on
I don't think I have that texture set. Are they labelled as "Materials Preset" or "Hierarchical Materials Preset"? The first type will only apply settings to the Genesis figure itself. The second one will also apply settings to fitted-and-parented eyelashes and fitted-and-parented anatomical geograft.
Does the IDG set include a separate anatomical texture material?
Yes it includes a separate anatomical texture material. However, even with the the Genesis 8 anatomy selected it still doesn't load anything when I try applying the anatomy texture material.
So, I just chatted with Sledgehammer in the Renderotica forums. Link here NSFW (http://www.renderotica.com/community/forums.aspx?g=posts&m=460219&#post460219)
Anyway, until I get the Daz male Genitals from a pro bundle I can't really try out his suggestion.
So I guess I have to wait until one of the pro bundles goes on a deep discount before I can try it out.
Anyway, consider this thread solved and thank you for the help and suggestions.
IDG Iray Essentials are for Daz genitals. Unless the gens you're using have the exact same UV map, and the textures have been assigned to work with them, they just won't work.
