Texture from V4.2 to G3M
in The Commons
Can someone please explain to me how I can apply a V4.2 face texture to a G3M character?
There is this product for G3F, but don't know of one for V4 to GM3
https://www.renderosity.com/mod/bcs/legacy-uvs-for-genesis-3-v4/113767/
This would do the trick: https://www.daz3d.com/genesis-3-uv-swap-male-and-female-base
Even if you use the product that changes the UVs to V4?
I'm trying it now, and maybe not. I have the V4/G2 to G8 versions, and the step that would need to happen in order for it to work across genders is map transferring to the standard G8 (or, in the OP's case, G3) UV, and I don't know how to do that with the geografts.
Use map tranfer to convert V4 to M4. Then you can use Legacy UV M4 product for G3M
I'd use Blacksmith Pro or Texture Transformer from rendo to transfer to G3F; you could then use UV swap to get from G3F to G3M. I transfer all my textures that way, with the exception of UV swap, which I've never done.
No, it wouldn't. The legacy UVs product doesn't transform a V4 texture into a G3F one, it modifies G3F so she can wear V4 textures.
At Rendo there's a wonderful Prae clown outfit: https://www.renderosity.com/mod/bcs/prae-clown-costume-for-g3m/123378/ and as a face texture is used in a G3M character a texture of another wonderful product of Maddelirium: https://www.renderosity.com/mod/bcs/mdd-my-little-dolly-for-v4-2/107159/
My question is: how do you do that? Thank you all for your answers, but I'm still not clear on how it's done. I've contacted Prae via Rendo, but I still don't have an answer.
Here are 2 rather simple options:
Thank you, Leana! I want to try the first option. I just need to know what steps to take to use Map Transfer from V4 to M4.
There's a tutorial about using map transfer here: https://www.daz3d.com/forums/discussion/184696/tutorial-from-map-transfer-to-material-presets/p1
It was made for a transfer between various G3F UVs, but it should be roughly the same with the following differences:
There was a product doing V4 to M4 transfer more easy, but it is not active just now in the store:
http://docs.daz3d.com/doku.php/public/read_me/index/7802/start
oops !
