Problem with Hair SOLVED
Fae3D
I've never had this happen before. I am using Channen Hair for Genesis 3 & 8 Female(s) and Naughty MoHawk for Genesis 3 Female(s). When I try to render them, I get this problem with a ton of white pixels all over them (see attached).
I have used both of them separately many times, and never had a problem with them. I have tried several different lights, from different vendors. I have used the low-shine version of Channen Hair, and I think I managed to turn off the gloss on the MoHawk.
It starts looking like this early in the render time, and never gets better (in some lightings, it gets worse as the render progresses). Using a Mac and Iray on the latest released version of Daz Studio (not the beta).
Has anyone had this happen?
it Might Be Some Shader is not Set Right Look at the Hair Shaders and see if one is Got some kinda Metal or Odd Gloss Turned on.
Thank you for your advise, I turned off all of the metallic and gloss features of the MoHawk, and it seems to have fixed it!
Thanks again! ^_^
