dForce Winter Trendy problem- Solved! =)
Apologies if this is the wrong place: there doesn't seem to be any thread regarding this product.
The Winter Trendy outfit loads fine (and renders well, too) with the default textures. But when I select an item and try to change the textures to one of the Winter Trendy Add-On I get the following error message:
Am using Daz Studio 4.12.0.86, Windows 7 Ultimate and haven't had this problem before either with Daz content, or content from other sites.
While I can manually change the maps it something I would rather not have to do.
Hoping someone can point me in the right direction and hoping everyone is staying safe and healthy in this time of pandemic.
Post edited by 3dLux on
Here is the error from the log file (tried changing the textures for the leggings than the boots). Also did a fresh download of the Winter Trendy outfit
2020-03-20 23:08:03.509 File loaded in 0 min 1.2 sec.
2020-03-20 23:08:03.511 Loaded file: Winter Trendy Outfit.duf
2020-03-20 23:08:03.615 Loaded Morph Deltas in 0 min 0.0 sec.
2020-03-20 23:08:03.620 Loaded file: Ankles Shrink.dsf
2020-03-20 23:08:04.731 Loaded image HT_Leggings Black_BaseColor.png
2020-03-20 23:08:05.131 Loaded image HT_Buckle_BaseColor.png
2020-03-20 23:08:05.232 Loaded image HT_Sole_BaseColor.png
2020-03-20 23:08:05.394 Loaded image HT_Leather_BaseColor.png
2020-03-20 23:08:05.843 Loaded image HT_Neck_BaseColor.png
2020-03-20 23:08:06.158 Loaded image HT_Cuffs_BaseColor.png
2020-03-20 23:08:06.267 Loaded image HT_Main_BaseColor.png
2020-03-20 23:08:06.498 Loaded image HT_Jacket_BaseColor.png
2020-03-20 23:08:06.649 Loaded image HT_Buttons_BaseColor.png
2020-03-20 23:08:09.244 Loaded image HT_Leggings Black_BaseColor.png
2020-03-20 23:08:16.161 Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
2020-03-20 23:08:16.161 Error reading file, see log for more details.
2020-03-20 23:08:20.541 Loaded image HT_Jacket_BaseColor.png
2020-03-20 23:08:21.570 Loaded image HT_Leather_BaseColor.png
2020-03-20 23:08:28.756 Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
2020-03-20 23:08:28.760 Error reading file, see log for more details.
2020-03-20 23:08:44.068 Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
2020-03-20 23:08:44.068 Error reading file, see log for more details.
That bit about "preset_hierarchical_material" means that you can only change the material if the clothing is fitted to G8F. It's dumb, but not a bug or glitch. The clothes just have to be on a figure before you chan change the material with those presets.
Wow! Thanks muchly @zombietaggerung! I actually did put the clothes on a custom G3F and encountered the problem when trying to change the textures. That's when I tried it with the clothes themselves, as seen above
I loaded the clothes onto G8F and was able to change the textures with no problem at all. I still wasn't able to change the textures when G3F was wearing Winter Trendy, but saving a material preset from the outfit when worn by G8F did the trick
Thanks for pointing me in the right direction; you're a lifesaver
Glad to help
