ERROR WITH STRAND BASED HAIR
socialpurposessocialpurposes Posts: 14
edited March 2020 in Daz Studio Discussion
hi, i need help, im making a scene with 8 genesis female, and it works well, but when i start making a strand based hair and save the scene, when i open again the scene it doesnt open and it crashes all my scenes that ive been create with strand based hair.. i save as as scene, its because of that? literally every single scene that have strand based hair it wont open anymore
 CPU Information:
 CPU String: AuthenticAMD
 CPU Brand String: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx
 Cache Line Size = 64
L2 Associativity = 6
 Cache Size = 512
Stepping ID = 1
 Model = 8
 Family = 15
Extended model = 1
 Extended family = 8
 CLFLUSH cache line size = 64
APIC Physical ID = 2
Supported CPU Features:
SSE3 New Instructions
 MONITOR/MWAIT
 FPU On Chip
 Virtual-8086 Mode Enhancement
Debugging Extensions
Page Size Extensions
Time Stamp Counter
RDMSR and WRMSR Support
Physical Address Extensions
Machine Check Exception
CMPXCHG8B Instruction
 APIC On Chip
 SYSENTER and SYSEXIT
 Memory Type Range Registers
PTE Global Bit
Machine Check Architecture
Conditional Move/Compare Instruction
 Page Attribute Table
Page Size Extension
 CFLUSH Extension
 MMX Technology
 FXSAVE/FXRSTOR
SSE Extensions
 SSE2 Extensions
 Hyper-threading Technology
Physical Memory:
5.8 GB (6312697856)
Avail: 2.6 GB (2822094848)
Virtual Memory:
Total: 127.9 TB (140737488224256)
Avail: 127.9 TB (140732871524352)
Current Memory Usage: 55%
Temp Data:
Location = C:/Users/Usuario/AppData/Roaming/DAZ 3D/Studio4/temp
Disk Total: 1.8 TB (1999721459712)
 Disk Avail: 1.6 TB (1824554696704)
Post edited by socialpurposes on
  • davidtriunedavidtriune Posts: 452
    can you
    1. open up daz
    2. go to help->troubleshooting->view log file and look near the bottom of the text file to see what error it gives?
  • nonesuch00nonesuch00 Posts: 18,765
    You may have turned on iRay Preview in the DAZ Studio ViewPort or changed how much resources the ViewPort can use. Open DAZ Studio wthout a scene and change the viewport setting back to their defaults.
  • can you
    1. open up daz
    hiiiiii, thanks for answer<3 look, i search and i see a lot.
    i see a lot of forums about this but i think i dont get it yet so first i uninstall daz studio pro with DIM then i installed again and this happened first:
    PostgreSQL CMS connection, such as context aware content views and loading content installed using the Daz Connect service, will not be available.  Check your network, anti-virus, and firewall settings for conflicts.
    (I think I had already appeared before )
    i see that has a lot of problems but i dont get it:(
    020-03-19 12:47:03.881 Error writing author data.
    2020-03-19 12:47:04.030 Iray [INFO] - API:DATABASE ::   0.0   API    db   info : Loaded "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\libneuray.dll"
    2020-03-19 12:47:04.030 Iray [INFO] - API:MISC ::   0.0   API    misc info : Iray RTX 2019.1.3, build 317500.3714, 19 Jul 2019, nt-x86-64
    2020-03-19 12:47:04.034 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(419): Could not add path: "C:/Users/Usuario/AppData/Roaming/DAZ 3D/Studio4/shaders/iray". Due to unknown error -2
    2020-03-19 12:47:04.034 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(419): Could not add path: "C:/Users/Usuario/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/iray". Due to unknown error -2
    2020-03-19 12:47:04.034 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - GPU:RENDER ::   0.0   GPU    rend error: NvAPI call NvAPI_Initialize returned an error:
    2020-03-19 12:47:04.034 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - CUDA:RENDER ::   0.0   CUDA   rend warn : CUDA module initialization failed.
    2020-03-19 12:47:04.034 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - CUDA:RENDER ::   0.0   CUDA   rend warn : The version of your CUDA driver is 0.0, but 10.1 is the required minimum
    2020-03-19 12:47:04.034 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - CUDA:RENDER ::   0.0   CUDA   rend warn : Please update your display driver (current version ).
    2020-03-19 12:47:04.058 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - LINK:PLUGIN ::   0.0   LINK   plug warn : Loading C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\nvcuvid_video_decoder.dll: No se puede encontrar el módulo especificado.
    2020-03-19 12:47:04.065 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\screen_video.dll".
    2020-03-19 12:47:04.093 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [ERROR] - IRAY:RENDER ::   1.1   IRAY   rend error: NvAPI call NvAPI_Initialize returned an error:
    2020-03-19 12:47:04.093 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.1   IRAY   rend warn : CUDA module initialization failed with error 'CUDA driver version is insufficient for CUDA runtime version' (0x23); iray photoreal can only run in CPU mode. Please update your NVIDIA driver (www.nvidia.com).
    2020-03-19 12:47:04.093 Iray [INFO] - IRAY:RENDER ::   1.1   IRAY   rend info : Using iray plugin version 5.0-beta, build 317500.3714 n, 19 Jul 2019, nt-x86-64-vc14.
    2020-03-19 12:47:04.093 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.1   IRAY   rend warn : There is no CUDA-capable GPU available to the iray photoreal renderer.
    2020-03-19 12:48:02.788 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
    2020-03-19 12:49:23.019 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
    2020-03-19 12:51:06.504 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2020-03-19 12:51:06.624 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Tcp shutdown called on a Tcp connection without a shutdown
    2020-03-19 12:51:08.330 Iray [INFO] - IRT:RENDER ::   1.1   IRT    rend info : Shutting down irt render plugin.
    2020-03-19 12:51:08.496 *** Scene Cleared ***
    2020-03-19 12:51:08.954 DEBUG: End DAZ Studio to Hexagon Bridge log...
    2020-03-19 12:51:09.287 --------------- DAZ Studio 4.12.0.86 exited ------------------
  • You may have turned on iRay Preview in the DAZ Studio ViewPort or changed how much resources the ViewPort can use. Open DAZ Studio wthout a scene and change the viewport setting back to their defaults.
    hi thanks for answer,  i see that my viewport always is on texture shaded or smooth shaded! but when i use iray i dont have any troubles(when i open the scene is on smooth or texture, when i want to see like lights or something, I usually use ithe iray mode) its that what u saying? :)
    i cant see any button that says turn viewport as default or something:(
  • do u guys think that i need to uninstall everything and install evrerything again???? i want to do it but im not really sure, bc i do some actors and i dont know if  i uninstalled everything my files are going eliminated too
  • socialpurposessocialpurposes Posts: 14
    edited March 2020
    i try to run daz as administrator but my computer says this:
    Permissions Error
    Daz studio cannot be run with elevated permissions
    maybe this is not the problem, but im trying everything i see on the forums but i think this is another problem,, cause it happends just when i use strand based hair
    i can open another scenes without strand based hair, but every single scene that have strand based hair, it wont open anymore and i dont know what to do :C
  • Richard HaseltineRichard Haseltine Posts: 108,488
    Permissions Error
    Don't try to run applications as dministrator - it is likely to create issues with folder/file permissions that may stop the application from running in future. If you had tried it wth an older version of DS, or with Install Manager, it maya ccount for the issue connecting to PostgreSQL.
    Permissions Error
    hiii, nooo i didnt, i just see on the forums but my computer says that it cant be possible so i didnt, and nooo, this computer is new and i install daz with this new update
    What security software are you running?
    edited March 2020
    hiii i really aprecciate that you answer my questions <3
    i running Avast Free Antivirus and Windows Security is activated
    i uninstalled daz studio with my antivirus turn off, then i installed again with DIM, again, with my antivirus turn off... but i dont uninstalled my DIM...
    I had also downloaded Daz Studio directly from the website, but it was 4.11, then 4.12 appeared and I downloaded it from the DIM.
    I checked my downloaded programs on my computer and I still had 4.11 and its Postgrade installed.
    uninstall it because now I have everything in my DIM
    Did you notice this line in your error log?:
    It is saying that you need to update your drivers. That is probably the answer. Did you try doing that?
  • Did you notice this line in your error log?:
    hiii, sorry i dont know T_T what driver do i need to update? im gonna try to update all my drivers then!
  • LeanaLeana Posts: 12,817
    You need to update the driver for your graphic card.
    its says that my drivers are all updated (for my graphic card)
  • Are you aware that if you go to the Nvidia website to look for updates, that there is a Studio driver? That may help.
    Where do you see that?
    Also, what graphic card do you have exactly?
