Resource Error - could not open File
R25SR25S Posts: 595
Hi,
I installed my content on my new PC and evereything is shown in the content library/smart content but when I try to load anything I get always an Resource Error message.
As far as I can see the path is not correcty inside DAZ Studio. It should be stated E:/........ but it only shows up as :/.......
Inside Content Directory Manager it is correctly stated as E:/......
As I found out now, this does not happen with all content. Some work fine and some didn`t.
Can anyone tell me how to fix this problem?
Post edited by R25S on
  • Richard HaseltineRichard Haseltine Posts: 111,482
    If you set the root of the E: drive as your content directory that may be the issue - tryusing a folder on the E: drive instead. How did you nstall the content, through Install Manager or through DS itself?
  • R25SR25S Posts: 595
    Hi Richard,
    actually the root is not pure E:/ it is "E:/Applications/Data/DAZ 3D/My DAZ 3D Library"
    I use Install Manager.
    Ok, if you go to the Products tab of Smart Content do you have a circled downward-pointing triangle icon in the top-right corner of the products that are not working?
    No; as you can see on the screenshot, there is no circled downward-point.
    Even in the Install Manager they are statet as installed.
    The screen shot shows the Files tab, not the Products tab.
    OK, my fault.
    But even in the Products Tap their is no downward-point (for the installed products, like the Zeke).
    I think the Problem is the missing E:/...... in the Path, so DS doesn`t located the .duf File. In the Info Tap, below the Files, the Path is correct beginning with E:/ but DS try to load it from :/
    If I browse to file location and click the .duf their it will load withaout problem (only problem is that is does load in a new DS Window and not in the one that is already open).
    1920 x 1080 - 561K
    1920 x 1080 - 447K
    The lack of a circled triangle means that the products are shwoing as installed through DS - the files that should be there from that will be used i preference to the ones from the DIM install, even though the latter are still there. Right-click on the thumbnail and select Uninstall - that will clear he Connect install from the database and should allow DS to use the DIM install.
    Hi Richard,
    uninstall through DS and install it with Install Manager solved the Problem.
    Thank you
  • Thanks, this helped me solve the problem I had loading some of my Genesis 8 Females.
