Stange "Eyelash Shadow"? (solved)
Leo ChenLeo Chen Posts: 697
edited February 2014 in New Users
Why my Mr Caption's face has strange "Eyelash Shadow"?
Post edited by Leo Chen on
  • JaderailJaderail Posts: 0
    Because they did not MORPH with the Face, the eyelashes are just floating in space in front of the face. In surfaces turn them OFF with the opacity setting.
    Post edited by Jaderail on
    That's not a shadow...it's the eyelashes.
    Is that a custom sculpt?
    If it is, somehow the eyelashes became detached from the rest of the head.
    If it is a paid/distributed morph, then a support ticket needs to be filed...same reason. The eyelashes are not following with the rest of the morph.
  • Leo ChenLeo Chen Posts: 697
    Thank you, mjc1016 and Jaderail.
    It is Freak5 super + Morph (shape and scale up).
    After adding pose, "Freak5 super+Morph" was scaled down that I scale it up again.
    I don't know how and when the eyelash is not on the right place.
    I just deleted the eyelash from surfaces(color) pane by setting Opacity Strength to Zero.
    Yes, you are right,it is eyelash!!!
    Thank you,Jaderail and mjc1016.
    From image1, you can see 2 pairs of eyelashes!
    781 x 569 - 557K
    879 x 815 - 697K
  • PuntomausPuntomaus Posts: 450
    Under Shaping - Eyes - Universal - Real World there's a Eyelashes Hide Layer dial. Try setting this to 1 and see if this will remove the second pair of eyelashes that got detached. If it only removes those that are still in the right place then you probably have no other option as making the entire eyelash surface invisible as you've done already.
    You are GOOD.
    Thank you, Puntomaus.
    After setting it to 1.0, the wrong eyelashes do go away.
    And I still keep one pair of eyelashes left on the right place.
    BTW, how that wrong pair of eyelashes come from?
    1295 x 637 - 485K
    Glad it worked :)
    The eyelashes are part of Genesis, it has two eyelash layers. It looks like this eyelash problem is caused by a morph that only moves one layer but leaves the other in the default position.
    Puntomaus said:
    Glad it worked :)
