Does DAZ Studio have a quick way to increase saturation?
In Poser, there was an HSV node, allowing you to change the saturation of the image very quickly by playing with a dial, does DAZ Studio have a means of changing the saturation of an image map on the fly? I could do it in photoshop, but sometimes all I need is a small adjustment.
Post edited by Flortale on
Tonemapping has a Saturation setting. You might looking through the Render Settings options enlightening.
This is great. Would be even better if it work by figure, not just the whole scene. This at least gives me a sense of how much saturation I need to add via photoshop. It saves a lot of time to get the right sat via this tone mapping. Thanks!
You could composite although modern versions of Photoshop Elements make it easy to do what you are talking about.
Can you give me some more insight into this? Jsut enough to get my foot in the door. By composite, do you mean rendering the figure as a separate layer in DAZ, then altering that layer in photoshop element?
