Unable to edit character animation
Hi all,
I recently made a 120 frame long animation using key frames. It turned out pretty well and I have some audio I wanted to layer over the top of it. Some of the speech didn't match up with a Genesis 3F character so I need to tweak the mouth open stats so it more closely alligns with the audio.
The problem is it seems I can't edit this character at all. For example, if I change her mouth open pose from 0% to 100% it will show but the second I click to the previous frame it will return to 0%. I've tried adding it as a key at 100% but it still makes no differene. It doesn't affect the other character in the scene who is Genesis 3M. It's driving me crazy and I'm about ready to throw in the towel.
Any ideas?
You had the g3f selected when you added the keyframe? keyframes aplly to objects or sub objects, not the entire scene.
I doubt you have run out of keys, you clicking the x and not the + because your tierd?
Definitely selected. I can confirm I can edit the same character in different scenes. I can edit other characters in different scenes.
It's rather frustrating.
