De port and Re port . . .
!green_9dd09f3341
OK, I found out how to unport the parameters pane so I could stretch out the list, but have no figured out how to re-Port it back to where it was . . . has been a real pane looking for it but the 'Help' isn't any help so if someone would tell me how to stick the parameter pane back into the bottom portion of the ported panes, I would really appreciate it.
Thank you,
CSGreen
Post edited by !green_9dd09f3341 on
Just drag and drop it back where you want it.
I keep trying that and it don't drop, just sits on top
I assume Lock Docking/Undocking isn't checked in Window>Workspace?
SOLVED . . . how do I close or delete a solved problem?
You might post the solution, for the benefit of others who may find this thread when searching on the same issue.
O.OK.
locking or unlockin not bothered. I kept sliding and dropping until I got mad and I finally had it all messed up and the center window was halfed, so I undocked the lower on and the the view port was full height .. . the I slapped the parameters sideways to get it out of my way and it just joined back where it belonged . . . but when I was sliding it over there on purpose to get it docked as Scorpio told me, it wouldn't work . . . so it was a fluke. I really need a default docking toggle . . . lol
