photoshop bridge !
i have the photoshop bride available in DAZ3D , but i cant get it to show up in photoshop , any help will be much appreciated !!!
It should show up under File >Automate in Photoshop.
Photoshop and Daz Studio need to be the same bit (both 32 or both 64) for the bridge to work.
The bridge doesn't seem to work on Photoshop CC.
If neither of those are the issue, how did you install it?
i installed it the normal way i believe
Your app paths are messed up. You have Daz Studio going to Photoshop and Photoshop going to DIM and all sorts of other nonsense.
It's pretty straight forward. Set your Daz Studio path where Daz Studio is installed and Photoshop path where Photoshop is installed.
Your paths will be different, but take a look at mine. I'm not pointing to plugins, or DIM, or anything. I have the correct app name set to the correct installed to paths.
i set mine to that and it still doesnt work :/
it works in daz3d but not in PS
Can you post a new screenshot of your app paths in DIM?
It happened to me too. Don't panic. Just uninstall and reinstall. If it doesn't appear, just uninstall and reinstall again. Maybe and again. I've consulted the support and we talk back and forth for a week. And now it works because I reinstall it twice.
