how do I find a required path for "Photoshop 3D Bridge for DAZ Studio ?
i keep getting the message " Install Manager cannot find a required path. The installer for "Photoshop 3D Bridge for DAZ Studio 4.5+ (Win 64-bit)" requires that the installed path for "Photoshop CS6, CS5, CS4 (64-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again. " and i have no idea how to fix it , i have seen others post about this but i dont know how to make the path , so step by step help would be much appreciated !!
Go to the cog wheel in the upper right corner of your DIM viewport. Select the applications tab. Add the path to your photoshop
i dont understand what im doing wrong , it says the same message after wards
You have the name listed as DAZ Studio, it should be Photoshop
which name ?
i got it , thanks !!
now how do i get it to show up in photoshop ??
In Daz Studio, go to File > Initialize Photoshop 3D Bridge
In Photoshop, go to File > Automate > Daz Studio 3D Bridge
In DS, be sure the 3D Camera is the active camera when you want things to import into Photoshop.
As for the DS Panel in Photoshop:
Preview, Update Image, and Auto Update don't do squat.
Render to New Layer is self explanatory.
Export Scene as U3D/DAE is if you have the Extended version of Photoshop. These will allow you to import the scene for use in 3D mode.
Import Image Maps will import your chosen textures into Photoshop.
Export Image Maps will export your edited/chosen textures as copies to avoid overwriting the originals.
Some of these tasks require you to tab back into Daz Studio once you push the button. DS should flash in your taskbar to alert you.
