Exaggerated Expression
Hello!
Why any of the commercial expressions packet available here and there always look exaggerated once applied? All are really unrealistic.
I don't remember this happens before the G8 generation. Might it be some morphs I have installed, or is just something that everybody noticed? Thanks.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,217
    that is horrifying surprise
    are you zeroing a previous expression?
  • that is horrifying surprise
    Nope, In the screenshot I just loaded a char (that in the picture is V8 as it is, but the same with G8 and all the other chars), and load the expression.
  • fastbike1fastbike1 Posts: 4,079
    edited March 2020
    I don't see this behavior. It is likely that zon-zero morphs have been saved. Check used values when you load a character, then load the expression.
    Select you character, go to the parameters tab and click "currently used". This will likely hlep identify the problem although there are cases where the problematic morph slider may be hidden.
    Post edited by fastbike1 on
  • edited December 2021
    Good afternoon,
    Post edited by xbrabo_b6d168b9d1 on
