BELTS FALLS DOWN, PANTS STAY UP?
deeahr2169deeahr2169 Posts: 488
I have the Kruger gun for V4 and tried to fit the gun belt to G2F. It works after a fashion, you select the figure and load the belt and get what is shown in screen shot one. Then you apply the fit to and what you get is shown in screen shot 2. Not much to do with this, must be something i am doing wrong i think, but what...
    I don't have this item, so I can't check it for you.
    If the item is made for V4, then you would need to try to fit the item as best you can to G2F, then use the 'parent to' and not fit to get it to remain where you placed it.
    I doubt if Autofit would work on this kind of prop item, but you would also need the V4 shape for Genesis 2 Female to get it to appear in the first place. V4 items do not directly convert to G2 without the clone.
  • jerriecanjerriecan Posts: 470
    According to the product page, this isn't a conforming item like other clothing - I think that means it has to be positioned manually. :(
