How to get the beard Old Man Rex?
jorge dorlando
Hello,
I bought the Old Man Rex for Genesis Character, 3D Universe
then morphs is working, but the texture and beard not appear in the library
the texture of his skin in the image, is the pattern of genesis.
I'm using PP2012
Did you look under Hair...
\People\Genesis\Hair\3D Universe\Rex\Rex Beard.duf
That's where the readme says it is...also I have noticed lately some files do not always end up going into Daz, least for me, so I end up opening the folders and copying the files over myself that are missing. I should pointed out I download the zip files and do not use the DIM. I would check to make sure the files are where they are suppose to be on the computer, if they are there, then I bow out to someone else who can help.
Well ... In daz studio they work, but not in poser Pro 2012
on the product page says there is a 1 DSON Core Installer
but all I could download is a zip file containing a folder named content, files containing ... but without the installer
http://www.daz3d.com/old-man-rex-for-genesis-character
DSON Core is the Daz Studio file. What you need to look for is PoserCF/DSON Companion installer, which this product doesn't have, so you need to create them yourself.
http://www.youtube.com/watch?v=TgGNBlO_yZw
Even then, there's no guarantee they will work properly.
okay
But ... as I do to return my daz studio to load the characters, not in block form as in the picture?
Hmmm, I thought the script DSON installed in poser did all the work yourself.
thanks for the tutorial
interesting ... I think I did it once, in mid-2012 when there was the fever in the forum, to put genesis in poser.
I had forgotten about that ...
You have it set to bounding box, I am trying to locate how you change that, but it has to do with your view of the model...lol...will try to hurry and find the answer.
Edit...found it...up near the right corner of you window, you see Perspective View, next is a little ball and next to that is some lines. Next to the ball is an arrow, click that and the drop down select texture shaded, that should give you what your looking for.
To change it from bounding box is in the upper right of the viewport next to where it says Perspective View in the screenshot.
LOL Vaskania we posted at the same time. I should point out I gave the instructions for Daz 4.5 but think is should be the same in 4.6?
Yep. :) I know it's in the same place when using the Darkstyles theme, but I don't know what the other workspaces/themes look like.
To fix your 'cubism' masterpiece...
Look next to the view/camera dropdown box and...
Hi all!
Thanks to everyone for the tips, it could make Daz Studio back to normal as you can see in the image.
Now I'll watch that video link again, and try to create the beard to work in poser.
From then on, I want to turn this old man into a farmer, an agricultural laborer, but not with those overalls, no. More like cowboy clothes (jeans and plaid shirt, or white, boots, hat and belt)
I have cowboy clothes for M4 ... Daz Studio can fit it to Genesis, ... But there saving a clothing M4, fited in genesis, and use it in poser?
Hi,
Now the only problem is that his eyebrows, not going to poser ... And they seem to be made with the beard, because in daz studio when loading the beard eyebrows carry along, I do not know why this going wrong
Try this:
Load Rex and get him all set up the way you want him in DS, save him as a Scene Subset (File > Save As > Scene Subset). Now create Poser Companion Files for this new subset. Try loading that into Poser and see if it works better.
If that still doesn't work, the only thing is I can say is that there's never a guarantee that DS content will work 100% if transferred to Poser. The only way it's guaranteed to work, is if the product came with the PoserCF from the creator.
thanks for the tip, but even after some testing, the eyebrows will not.
Check for Opacity on them If they list in the Poser side. They may just be OFF to the view or not loading the materials properly.
