Set Active Viewport as the default when opening Daz?
I only use the Active Viewport view when working in daz. But sometimes when I open up a blank scene in daz. It gives me a custom viewport.
I don't want to always have to change it to active to get rid of the lines of a render viewport.
Can I lock it to always start on Active Viewport?
  • NorthOf45NorthOf45 Posts: 5,712
    If you are referring to the Active Viewport in the Render Settings->General->Dimension Preset options, I don't think it can be locked in. A New Scene uses what was used last. You can make a default empty Scene that sets the Dimensions to Active Viewport, and load that automatically when creating a new scene (Preferences->Scene: On "New": Load file). I don't know if it must be a Scene file, it might work with any type of file, like maybe a Render Settings Preset, where you have saved only the Dimension Preset, or any other settings you want to start with every time.
