posing / re-position
KeithHKeithH Posts: 338
Unsure what to call this. Some poses moves the character away from the arrows for moving. When doing that is hard to rotate or other things without it being a big deal.
How do I get the arrows back under my character?
This happens using poses from the content menu.
Thanks
  • atozedatozed Posts: 77
    This happens when a pose changes the translation of the hip bone. To fix:
    1) Select the character's Hip in the Scene tab.
    2) Set the X Translate, Y-Translate and Z-Translate settings to 0 in the Parameters tab.
    815 x 202 - 25K
    You can also prevent the translation from occuring when applying the pose. To do this:
    1) Press down the CTRL key on the keyboard, and then apply (double-click) the pose you want to use.
    2) When the Pose Preset Load Options form is displayed, uncheck the Translation options, then click the Accept button.
    291 x 346 - 26K
  • KeithHKeithH Posts: 338
    You are amazing - Thank you
