Timeline window problem
Hola!
When I activate the Timeline pane, it takes over my left pane completely and I can't use any of the other panes on the left. The only way I found to handle this problem is to switch to default setup (whice prevents me from doing anything after using Timeline, such as running a simulation).
Anyone else ran into this problem? Am I just a n00b who can't find the relevant settings icon or whatever?
Enclosed is a screen cap for reference.
1. Put the timeline tab back on the bottom.
right click in the blank area to the right of the Animate tab>Add Pane(tab)>select Time line from the menu.
2. Menu bar>window>Workspace>Orient tabs along top
3. minimize the right tab group.
I'd encourage putting it back down on the bottom section.
