G2F + PP2014- Not accepting textures, even Bree makeup
Lissa_xyz
I figured I'd give G2F a shot in Poser, and bought the V4 for G2F by Mallenlane. I thought I had an issue just with the V4 UV, but it turns out I have an issue with G2F altogether. I've tried using both the release and beta versions of the importer. I can't even apply the makeup from the default Bree texture.
The texture will change on the legacy numbered surface names, but remain unchanged on the new, unnumbered surfaces. It's like the textures aren't getting translated from the old names to the new.
PP2014 SR3
DSON Importer 1.1.1.39
I have both the DS files and PoserCF installed.
Last attempt from the log file:
DSON Importer
Setup
DSON Write Path: F:/!Libraries/Daz Studio Library/Runtime/DSON/auto_adapted
Parsing DSON File...
File Path: F:/!Libraries/Daz Studio Library/Runtime/libraries/Materials/DAZ Genesis 2 Female/Bree Face 01.duf
Scanning for dynamic assets...
Applying settings to actors...
Loaded file: Bree Face 01.duf
Importer Setup in 0 min 0.0 sec.
DSON File Read in 0 min 0.0 sec.
DSON Dynamic Read in 0 min 0.0 sec.
Applied Settings in 0 min 0.0 sec.
Total File Load in 0 min 0.0 sec.
Done
Post edited by Lissa_xyz on
Tried this in PP2012,and it doesn't work for me there, either. I'm not sure what's going on here. I've uninstalled the G2F Starter Essentials and it's PoserCF and went through and cleaned up the files that didn't get deleted with it. Deleted the zips via DIM altogether and redownloaded and reinstalled them. Didn't help.
I'd understand if I wasn't using PoserCF, or something that's not meant for G2F, but even her own default Bree texture? That should be working out of the box.
You know that V4 for G2F by Mallenlane is a product for DS, right? I think you'd have to apply the textures in DS and then save the PCF files to apply them in Poser. And the textures must be converted to DUF format first in order to apply them to G2F.
The entire post was because I can't apply even the textures that came with G2F. Applying let's say the makeup options that came with the Bree texture will not display any changes whatsoever. I thought the issues were only with V4 textures, but I can't use G2F's either.
Again, I'd understand if I was having issues with textures meant for another character, but I can't even apply G2F's own materials.
That is weird. Is it possible that you missed some file when you uninstalled the Starter Essentials?
Not sure how that would affect it's usability since it would only get replaced on reinstall, but no, I didn't. I followed the folder structure inside the zip and deleted the corresponding files within my runtime.
