Adding to Cart…
Kinda sounds like a heat problem? Maybe the board is defective, after all, like some are saying.
Thanks
Will try that - made some stress test today and the performance was perfect, but if you’ve seen the same faulty it could be the case.
I'm now fairly convinced you have some sort of hardware fault. It is possible the driver is a problem as well.
If you switch the cards between the machines and the issue remains local to the box not the card I'd get DDU completely remove the driver and install the latest driver again. If that doesn't fix the issue you could try doing a full reinstall of Windows. If that doesn't fix it I'd lean very heavily toward RMA of the mobo.
If the issue follows the card RMA the card.
You're right. It WAS the graphic card. Just switch the 2080-Ti and memory load drop almost 50 % for the same image to render and CPU load is now 38 % - not 100 %
Thanks for your help
