aniMate aniBlock Importer for Carrara
OldminerOldminer Posts: 135
Where can I get the aniMate aniBlock Importer for Carrara? I have DS 4.6 with a number aniblocks (animate & animate plus and some I created) and would like to import them in my Carrara 8.5 Pro. When I search DAZ Shop for aniMate aniBlock Importer for Carrara I get the Carrara Packages! Is there another site for the importer program?
  • bighbigh Posts: 8,147
    no its here - don't have link
  • DartanbeckDartanbeck Posts: 21,988
    I love this plugin! Keep in mind that aniMate aniBlocks work best with a linear tweener. So when you're going to import aniBlocks, go to preferences and find where you set the default tweeners, and set it to Linear. You can always change it back quickly enough if you prefer a different default at other times. I switch my default tweener setting in preferences all the time, and then switch out a few here and there to use something else.
    Here I have an article with some fun advice on how I use aniBlocks in Carrara, as well as some great links to tutorials that can further your experience using this wonderful plugin:
    ►►► AniMating in Carrara
    240 x 312 - 29K
    The tweener setting in preferences is under General Scene Settings
    699 x 696 - 297K
