Wolf2 - 28 of 35 Morphs/Options missing?
WsCGWsCG Posts: 391
edited February 2020 in The Commons
Hello,
Hoping someone can help me out here. I'm pretty new at D|S, so it could just be me not looking in the right place.
I purchased Wolf 2. Its product page says that it includes about 35 different morphs. However, there's only 7 for me. I've tried clicking on All, on each sub-item for the figure, etc. This is the case no matter which version of the wolf I load.
I've attached a screenshot to show what I mean.
I don't know if its creator is active on these forums, and I couldn't find any way to reliably get in touch with them about it.
Has anyone else here purchased this and had the same issue? Is there something I'm not finding? I'm at a loss.
Thanks a bunch.
Post edited by WsCG on
  • galiengalien Posts: 138
    Only a few of the morphs appear in the Shaping pane.
    If you switch to the Parameters pane, you should see all of them.
  • WsCGWsCG Posts: 391
    A ha! That did the trick. Thank you! You know, I'd clicked on Parameters, but only saw stuff not specific to that figure, so I didn't think to scroll down.
    Still learning!
    Thanks!
  • It is a bit of a head-scratcher until you wrap your head around it. There are several different single-purpose parameter panes; Cameras, Lights, Posing, Shaping etc. These all display only that type of parameter for whatever object is selected. If you don't know which pane something should appear in, and you happen to be looking in the wrong one, you could get stuck. The Parameters pane, though, shows everything.
