problem Transfer Utility
Hi there
I have a problem with the Transver Utility.
I created a skirt for the character Ronen in hexagon. Should be a fur kilt. When importing to daz, everything fits perfectly to the geometry.
but when I use the Tranfer Utility, the skirt increases and doesn't fit Ronen anymore. Can someone tell me why.
Thank's for help  Andreas
  • LeanaLeana Posts: 12,957
    edited February 2020
    If you have created the item to fit a morphed figure and not the base shape then you need to set specific parameters when using transfer utility: set the source shape to "current" and check the "reverse deformations..." checkbox.
    Otherwise the transfer utility will assume it's meant for default figure and adjust it to fit your morphed character, so it's essentially adjusted twice.
    Oh and does that character use scaling? That can cause problem too.
    Post edited by Leana on
  • now it works , thank you for the Council !!!
