Object import problems
wsxcwsxc Posts: 19
I'm trying to import my DAZ Studio scene (.duf) to Carrara 8.5. Everything is well excepts one thing: I can't import Scoopback MiniDress and it even cause the Carrara crash. When I deleted that dress, import was succesful.
Here's the log:
Warning:  duplicated in file \People\Genesis\Clothing\Scoopback Mini Dress\Scoopback Mini Dress.dsf
Warning: file /data/DAZ 3D/Scoopback Mini Dress/Scoopback Mini Dress/Morphs/DAZ 3D/Base/ADJFlower.dsf could not be found
Warning: Scoopback MiniDress duplicated in file \data\DAZ 3D\Scoopback Mini Dress\Scoopback Mini Dress\Scoopback MiniDress.dsf
Error: node /data/DAZ 3D/Scoopback Mini Dress/Scoopback Mini Dress/Scoopback MiniDress.dsf#Scoopback MiniDress not found
What to do?
    Is it dynamic? Otherwise it looks as if something with it couldn't be found. Is the file path broken?
  • wsxcwsxc Posts: 19
    Is it dynamic?I don't know.
    http://www.daz3d.com/scoopback-mini-dress
    No, the required file is placed just where it should be.
  • bighbigh Posts: 8,147
    Carrara 8.5 doesn't like duplicated files .
    edited January 2014
    Nope. Not dynamic. I don't have C8.5 or .duf so what help I can offer is limited. You could attempt to re-export from D/S and try and import the new file into Carrara.
    bigh said:
    Carrara 8.5 doesn't like duplicated files .I can't open Scoopback MiniDress even in the empty scene. By the way, other "native" clothing open with no problems.You could attempt to re-export from D/S and try and import the new file into Carrara.
    How?
    wsxc said:
    How?
    are you getting a warning from DS that you have duplicated file for Scoopback MiniDress ?
    if you are it will not work in C8.5 .
    How?
    Well, you got it into .duf format once right? Just do it again, following bigh's advice on not using a duplicate. I can't really help beyond that. Sorry.
    it will work if you don't have duplicated file .
    is this one you mean - I did this render in C8.5
    640 x 480 - 34K
    Yes, it is. I've just found a script that fixes duplicated files. It helped, and now I can import the dress. The only problem is that it appears as grey object and I can't use "Materials" subfolder to set the texture.
    great .
    are you trying to set texture in C ?
    do it in DS - works better .
    bigh said:
    great .
    read you post again - you want to open , not import
    bigh said:
    bigh said:
    great .
    once you get in C - you can change texture using smart content
    just did it .
    hope this help .
    I can't. No materials for Scoopback MiniDress in any Smart Content folder. It's only accessible via Content tab.
