Adding to Cart…
Like I said - I've been spoiled by IBM large Disk Storage subsystems- which provide all of these features - starting at just less than $1,000,000 for a 20 TB system that consisted of two 22-inch racks bolted together, weighed in at just over one ton, and required redundant 3-phase 240 volt 50 amp power feeds. Not something for even small companies. We had two, and our most critical data was software mirrored between RAID 5 arrays on both systems.
So, for home use, I still want a 5 year warranty and weekly (at a minimum) backups.
And most of us are running Windows.
The ten year old Seagate that failed this month started by reporting sector reallocations. By the time I got the replacement drives it had dropped off the system entirely and ended up with a head crash about 4 to 6 hours before I was ready to shut down. The WD Blue drive didn't report any errors and was working fine when I shut down to replace the Seagates. It just didn't come up when I restarted the system - no errors in the system logs, just not there anymore.
Just a reminder.. RAID is not a backup..! But yea, better than nothing ;)
That's crazy expensive. No idea how long ago that was sold but I could part out a 20Tb RAID 5 for less than $5k (6 4Tb Ironwolf Pro's at $140 each plus a $1000 RAID rack with 6+ bays and some RAM and a cheap Xeon).
We don't generally even build storage devices that small. We've been buying exclusively 12Tb drives for the last 18 months of so.
The WD probably had a motor failure on startup. That's a risk with any electric motor. It works fine until it is powered down and cools off then it never starts up again. That's why datacenters prefer hot swap. If one drive in a storage device goes bad it isn't inconceivable that the rest are not in great shape and a power down might kill the whole thing. So do a hotswap/rebuild and then get the data off the box and onto a new one.
Yeah - enterprise level storage, for the Z series, AS400s, RS-6000 systems, and large Intel farms. The only real competitor was EMC, and their systems were 40% more expensive. The last one I configured 12+ years ago was a 40 TB system with 16 fiber channel interfaces rated at 8 Gb/second throughput each. (4 cards, 4 ports each). The system had two RS-6000 servers as controllers running pretty much standard AIX (IBM Unix variant) with custom device drivers for the fiber that looked like disk to the client system. Each server had direct access to all the drives but 'owned' half of them.These systems were designed to support mission critical and enterprise critical environments that required 5 nines availability (99.99999 percent uptime, - a maximum of 5.5 minutes per year of outage).
Just look up "IBM DS8100" - it's a heckuva box.
That was what I figured; a ten year old drive that hadn't been shut down in four months. The box now has two 2 TB SATA drives, to be replaced with SSD when the 4 TB SSD become less expensive, three 2 TB SSD, and a 500 GB SSD as the system drive.
Yeah we don't do the IBM ecosystem. I get it if you've got legacy DB2 stuff but otherwise you're just overpaying. 5 nines uptime is pretty much standard in the enterprise now. We offer it, some clients don't care about the difference between 4 seconds a year and 40 so we offer them a lower guarantee, and do it with not just local redundancy but mirroring systems between physical datacenters.
We had a bunch of infiniband storage devices but increasingly we're switching to 40Gbit NIC's. It's just as scalable, just add more NIC's if you need more throughput, and the physical hardware and cables are cheaper. Personally I'll be quite happy to see the last of our fiber gone.
Made my decision, made my purchase. After all the bad reviews and sleepless nights, I took a chance and ordered an external (instead of internal) WD 6GB drive. It was on sale, I couldn't resist the price and it fits into my existing zoo of several external, variously sized, hard drives nicely. Letting me move a recently purchased WD 2TB drive that has been in use as an archive for at least a year, currently being used as an external but will now be moved to be an internal in my DAZ machine giving me a total of 5.5TB internal on that machine. I'm playing musical hard drives but once I get the data all shifted around I'll have multiple redundancies for both my main machines. However, to protect myself against the new 6TB external drive failing the day after the manufacturer's warrantee expires I did buy the longer warrantee offered. I don't usually do that but it wasn't expensive and I'm getting skittish in my old age.
