dForce only using one core
amandainjapan
Hi, all.
I've noticed that Daz is only using one CPU core. How can I fix this, or is it just not an option in the software?
amandainjapan
Hi, all.
Is it set to use CPU or a GPU? You're probably using your GPU and the CPU is just baton waving.
It is set to GPU. But even with things like loading items or saving it only uses one core.
Almost everything has to run through the CPU at some point.
This is normal software operations, and not limited to DS.
nothing to concern yourself with.
IO is inherently very difficult to multithread. A disk can not do multiple things at one time so only one thread can access a specific drive at a time. Therefore making a bunch of threads to read files is counterproductive.
