New Morph Issues (ERC Freeze and Skeleton)
Okay, I'm making a new morph. Or rather an edit of an old busted one. I dial in the morph, adjust the skeleton to match, add limits, export as a Morph asset... and in generally yey, it works perfect.
Then I save the Morph asset and it doesn't recognize the skeletal changes or the limits when I load in a figure.
What am I doing wrong?
You list ERC Freeze in the thread title but not in the steps you took. If it's an old morph, with joint adjustments, are you doing an ERC Bake first - you shouldn't do an ERC Freeze on a proerpty which already has ERC dependencies.
Fixed it.
After I redid the morph to work properlly I needed to delete the old morph.
