Starting daz a second time doesnt work
Loony
Hi,
I have daz open, but wanted to open it again to dforce there a subset, but... for some reason do i now stuck in "starting plugins".
I'm a bit afraid, what happen if I also close my current daz, will I be unable to open it also? ;(
atm. I am using the new Mesh grabber 1.9 beta:
https://www.daz3d.com/forums/discussion/comment/5362401/#Comment_5362401
maybe it doesnt allow double instances?
I could open daz today already 2x, but the interface got white like in my screen, no response "white".... so I killed it.
maybe that kill did now killed it complete? :(
Post edited by Loony on
You could try getting the beta, then you would have two independent versions. Note that going forward running two instances of the same version of DS will be handled differently - it's currently exploting that the behaviour isn't blocked, and can cause issues, but in future it will require delberate actions and will be made safe. As for now, I don't think you have any option but to force quit.
yeah I can't run the second instance... it worked well in the past, but not today :(
I am confused, why I was able to run in the past daz always 2x, but today not anymore...
I did now closed my dazstudio AND as I assumed... now it will not start anymore ;).... GG!
maybe a windows restart will help, but I assume the MeshGrabber 1.9Beta is the problem :)
Sounds more like a corrupted file of some kind, possibly as a rsult of trying to run a second isntance. This is one of the rare instances when I might suggest reinstalling DS.
https://www.daz3d.com/forums/discussion/comment/5365226/#Comment_5365226
ManFriday is knowing the bug, so its belonging to that, you can close this thread :)
