Looking for 'barbering' props and poses
comixfana
in The Commons
Thus far, the closest I could find to what I'm looking for is the Sweeney Todd bundle, which is rigged for Genesis 2 characters (mine are Genesis 8). All I need really is a pair of scissors, a straight razor and poses for a Genesis 8 Male getting a shave and a haircut (preferably from a Genesis 8 female). I've looked at Daz and Renderosity marketplaces, and CGShare...once again, the closest product for my needs is thw Seeney Todd.
Maybe I'm using the wrong search parameters? Haircut pulls up every hair prop and textures available, ditto with hairstyle. Barbershop gave me the closest match (Sweeney Todd) but that's not quite it either; any suggestions?
Thanks!
Try "salon":
https://www.daz3d.com/hair-salon
https://www.daz3d.com/small-type-salon
https://www.daz3d.com/chez-lucille-hair-salon
There's this, but it doesn't have poses
https://www.daz3d.com/barbershop
Not sure why the store search engine wouldn't have found that for you; "barbershop" should have worked.
Judging from the file list, the structure of the shop -- walls, ceiling, floor -- is all one piece; you can't use the eyeball in the Scene tab to hide the walls if you need a better angle.
And this is a nice set (no poses, however).
I am not sure whether links to other websites are allowed. Try Renderosity website and search for "barber". There is a bundle containing tattooist and barber props and poses. The name is a bit misleading, as it only mentions tattooist in the name, but it contains barber stuff too.
Edit: I forgot to mention it contains poses for Genesis 8.
Pamawo has a set of poses over at renderostity with the straight razor and shaving brush poses for both G8F and G8M. They go specifically with his Tatooist and baber series but work fine with other props. A little pricey at regular prices but his store goes on sale for 50% off or better almost every month. Scissor poses are tricky as most of the items in both the DAZ and Rendo stores are fixed position props. I ended up faking a working set by making duplicates of an open-posed pair, parenting them to a null at the center and then hiding the opposing sides with the geometry tool... Best deal for barber tools in general is Mr. Sprky's old hairdressing salon set, which converts to iray pretty well and is now on clearance from Vanishing Point over at Rendo.
Can Genesis 2 poses be applied to Genesis 8 or would that look too weird?
Yes and no. Given that G3 and below all start from a T pose while the G8s start from an A pose, you'll need something that corrects the basic skeletal and base pose differences. There's a freebie script on ShareCG that convers between all the Genesis generations https://www.sharecg.com/v/89846/gallery/8/Script/Daz3d-Pose-Converter-Standalone
This is how you know when you have too much CG stuff. I was sitting there trying to think of where I had seen some barbershop poses, because I KNEW I'd seen them, so I googled it and found... my own reccomendation to someone else from a year ago for a product I already own. Facepalm.
