Broken morphs.
I deleted a morph and replaced it with the same morph under a different name, when I load a figure that used the older morph it can't find it so doesn't apply it.
Is there any way to find out what the old morph setting was?
  • If it's a purchased morph, delete the morph you made and reinstall the old morph.
    Suggestion: when making new morphs, give them unique names then you can have both of them ;-)
  • LeanaLeana Posts: 12,908
    Open the .duf file where you saved that character in a text editor, and look for the settings for the old morph. You may need to uncompress the file first (you can do this with a program like 7zip, or IIRC there's an option to do it included n DS).
  • Was a homebrew morph that was broken.
    Thanks for the info, opened scene in winzip and used the internal viewer, then confused myself trying to convert it to a percentage.......
