Question on installing carrara pro 8.5...
Kharma
First does carrara have to be installed to C:/Program files/ Carrara or could it be installed anywhere and second should content be installed into the program or does it have to go into the user/name/documents/daz3d folder ?
Thank you
I install mine to C:\DAZ 3D\Carrara8.5. It does not have to go into program files.
Edit, if you don't put it in program files, you can put the content in the main folder.
Thank you, that's exactly what I needed to know :)
