Characters reseting position from frame1 to frame2
Hi, I'm having an issue with my genesis 3 character when I load an animation for him. After the animation is loaded, I reposition my character so it fits with the props positions I have in the scene. But when I play the animation, the character resets to its initial position. Only frame 0 keeps the new position. How can I propagate the new position for the rest of the frames?
Thanks!
Sounds as if the bone/node you used to place the figure has a key in the second (and possibly other) fArames too - you would probably need to clear those first; select the figure or hip bone, whichever was used, and then use the Edit>Figure>Clear Animation>Clear Selected Item(s) Pose.
Thanks, I'll try that.
I thought about a workaround that worked as well: using a dummy empty object as a father.
