Videos created in DazStudio have a ridiculous bitrate
Hi there,
I have been trying to create some animation with DazStudio but the process is rather frustrating, after over 12 hours of rendering I finally created a 1 second animation BUT the avi files it generates have a bitrate of 1769472 Kbps (As far as I know blue ray ran about 40000 Kbps, the best coverter I could find in reality can produce mpeg at about 4000Kbps) which bring me to the problem. In order to be of any use the animation need to be converted into a compressed format BUT doing so makes it look like barf (Obviously since it means dropping the biitrate to 0.45% of the original). I would like a way to either keep the original quality or if I have to end up with a video that is over 200 time worst that what I planned at least a way to render it 200 times faster.
Thanks
I prefer doing animations:
1-saving each frame like "image series", then
2-using VirtualDub and
3-adding the first images allocates all sequentially in the software, then
4-adjust the Video Frame rate control to the same value of your animation.
5-Resulting in a fat file over 1Gb, then you can compress using any video edition software.
using image series you can decide use ALL your images or make small videos in sequence.
Render 200 times faster?
1-Rent a Renderfarm, or buy an expensive Nvidia Card with more than 2000 Cuda Cores
2-or Save as OpenCL
3-Using 3Delight engine
4-Using iRay with fixed iterations and HDR lighting
5-Using Scripts to compress temporary big textures
6-deleting bump, displacement, SSS setings and textures.
7-Eliminating geometry non visible on your camera for the final rendering
8-Lower subdivision or base setting on your assets.
I usually go from Daz to Premiere Pro or After Effects and via that pipeline you pretty much always want the most raw/uncompressed footage you can get. In essence, it's a good problem to have.
I render to an Image Series and then import to the free version of DaVinci Resolve for rendering as an .MP4 or other (don't think it supports .AVI though). Before that I rendered the image series in Blender, again with the output as MP4 or MKV (Blender does support AVI, if I remember correctly). I don't have the funds for pro software like Premiere Pro or After Effects but the free alternatives are good enough for me.
DaVinci Resolve will recognise an image series as long as they are sequentially numbered (as they must be, of course) and import the series as a single clip. With Blender, you have to select all the files and then use the Image Series import option.
