Poser to DAZ loading problem
EZ3DTVEZ3DTV Posts: 1,494
edited February 2020 in Daz Studio Discussion
I work mostly in DAZ Studio, but I have a lot of Poser models.
I have my Poser runtime showing up in DAZ studio content view.
When I select a Poser figure in the Poser formats part of the DAZ content view it loads in DAZ all contorted, and the geometry turns to spaghetti.
Is there an addon program I can buy in the DAZ shop that fixes this issue so these models load correctly and are converted to the correct DAZ geometry?
Thanks in advance for your response.
Post edited by EZ3DTV on
  • rrwardrrward Posts: 556
    I have a similar problem with V4 characters, though mine load fine, they turn into hirrific nightmares when I try to pose them. If I load a blank V4 figure it works okay. My fix was to document the morphs and such in Poser and recreate them in Studio.
    What was that figure supposed to be? Knowing that we might be able to figure out a fix.
    When you say "pose", do you mean manually or using a preset? What morphs are causing issues? When posing do you use the base node, or hip node?
  • BejaymacBejaymac Posts: 1,960
    Which version of DS are you using as I use Poser figures all the time and don't have this issue with them, that is the sort of thing I get regularly with FBX and Collada though.
    EDIT
    Wonder if this has something to do with IK in 4.12
    Post edited by Bejaymac on
