Please help...McJteleblender2 Error Message
edited December 1969 in Freebies
"Problem: Unable to open C://scene.mtl" (with both forward-slashes) appears every time I try to run McJteleblender2. Both scripts were extracted properly in their respective Daz 4.6 and Blender 2.69 program folders, as near as near as I can tell, and it's doing this on both my laptop and desktop, which are both Windows 7 64-bit.
Strangely, when I installed it on an older 32-bit machine (also Win 7), this didn't happen--it ran fine.
Please help. I would appreciate any assistance. Thanks in advance.
  • Richard HaseltineRichard Haseltine Posts: 109,378
    Try using a subfolder rather than the root (in other words, create a folder on your C: drive and tell the script to place its files there).
  • edited December 1969
    Thanks for the reply.
    How do you tell it to do that? I couldn't find the setting for it in the McjT window. Do you have to alter the script? If so, what program do you use?
    I've not used the script, but I would expect by using the Browse buttons next to the file names in the dialogue.
    Honestly, I thought those were presets you couldn't mess with too much without screwing up the script, in case it was writing things back and forth.
    But, I just went and created a new folder ( C:/blend)and switched them all to it. Now it works. Thanks again.
    Good, glad that worked.
  • mCasualmCasual Posts: 4,607
    edited January 2014
    when you click the script's "Export" buttons, the script saves the entire scene as an .obj file
    this obj file is accompanied by a .mtl file and a .bat file
    after you render the scene in Blender and optionally save your blender scene file, you could brose to this location and delete the obj/mtl/bat/bpy files
    the location of the .obj file can be anywhere on your hard disks ( if windows allows it )
    the C:/scene.obj is basically a fake location and filename and should be replaced by something valid
    using the "browse" button next to the "Export scene as obj" box
    947 x 567 - 93K
    Post edited by mCasual on
