wire frame
Can we increase the mesh size of an object (furniture, chair, table etc) or of a character in Daz studio 4.12?
the mesh for me is this
Do you mean you want less and bigger polygons? Or you want the size of the object bigger?
What I want to do is increase the subdivision of an object like the washing machine (represent by the cube on the left) and deposit another object and that the washing machine marries the shape of the sphere like the cube on the right because I use smoothing modifier
I would like to know if it is possible with Daz 4.12 increased mesh, polygons, subdivisions of an object like the washing machine
You could try adding a subd modifier, I am not sure if it's going to work, but worth a try. Edit > object > geometry > convert to subd. Then in the property panel it will allow you to crank subdivisions up.
Something like that, I would probably end up in blender or zbrush.
thanks for your answer is tried your solution, I can not say that it is conclusive I believe alas that it is not possible
Increasing subidivion levels depends on the underlying topology.
If it wasn't built with subdivision in mind and doesn't have the proper topology to support the deformations, you'll have unusable results.
